https://gearhooks.com/collections/gearhooks-guitar-and-musical-instruments-storage-rack
I’ve got really crap walls and have tried the Hercules hangers but they eventually wear free even though I’ve used all manner of fixings . These look as though I could get a good couple of fixings in but I’m not sure if the actual guitar hook part will be ok.
Thanks
BUT: If your walls can't hold Hercules hangers, they won't hold these any better (unless you only used short screws with the Hercules), AND the "soft rubber coating" might react with any nitro-finished guitars - it would be worth-while asking them about that.
FWIW I have five of these K&M hangers: https://www.amazon.co.uk/16280-black-Guitar-Holder-Black/dp/B000N5HU5A
They are on a masonry (breeze-block) wall, using 40 mm screws, and have been up for 20 years now, with no adverse reactions on nitro guitars.
They are solid as a rock and not budging now...just like the lady next door who was leaning against the joining wall when I drilled those fuckers in! Oops!
Just because you're paranoid, don't mean they're not after youCheers ,they look ok and I could always screw them to a plinth fixed to the battens behind the plasterboard,
a lot cheaper too!
Didnt use the Hercules screws.
Fischer HM 5x65 metal fixings with screw. The Fischer screws are slightly larger diameter than the Hercules ones (probably a good thing) so I widened the holes in the Hercules wood block slightly with a drill bit to accept them. Feels rock solid. The Fischer’s can apparently take 20kg in plasterboard so plenty.
