Wiring problem, guitar gone quiet - now fixed
AustrianJohnAustrianJohn Frets: 1682
edited May 2019 in Making & Modding
I have a baritone with two humbuckers wired like this.
https://www.dropbox.com/s/vgbeok1cmrustb2/wiring.png?raw=1
Last week it worked fine, today the volume is very, very low - too low to register in my tuners, but with lots of boost just about useable, but noisy.
I checked the wiring and it looks fine. While prodding around I notice that if I short the connections on the pot that go to the jack and to the switch, the correct volume level returns, and the volume pot works ok.
Obvious answer is to connect the two lugs on the pot, but I'd like to understand what's going on.
Can anyone explain?
  • AustrianJohnAustrianJohn Frets: 1682
    edited May 2019
    Problem solved - I resoldered the pot connections and it now works perfectly.
  • FunkfingersFunkfingers Frets: 14453
    edited May 2019
    Most probably a poor ground connection on the volume pot chassis.
    Having worked perfectly yesterday it again stopped working today, so I redid all of the electrics and its now ok ... for now.
    I'll double check the ground connection tomorrow.
  • ICBMICBM Frets: 72410
    It won't be the ground connection - that would make the volume nearly full all the time, and only drop a little as you turn it down.
    If it's not the soldering it will be either a poor contact between one of the terminals and the trackboard, or between the rotor and the track. You can usually fix the first by squeezing the rivets with a pair of fine-nose pliers. The second is normally game over unless you want to try taking the pot apart and bending the contacts slightly so they put a bit more pressure on.
    Thanks. After re-soldering the connections and a spray with contact cleaner its working. Any more problems and I'll replace the pot.
