Sorry if this has been posted before but I'm at the top of the waiting list (or near it) and will be expecting an email soon from analogueman asking for my options. I have thought I didn't need one now but I'm thinking I'll be foolish not to buy one after a long wait to at least try it with my rig. I suppose I could sell it on without losing too much in revenue if it wasn't what I was looking for. Hopefully not though as I hate flipping stuff - just can't be bothered with the hassle etc.
So my question. What would you guys suggest as a usable good options to spec? So far I'm down to 4 jack option and the higher gain one side. Maybe White or Black
. What others should I consider?
Thanks again guys you are always my initial point of call
ps - the object of flipping a KOT is to *make* money, not “lose too much revenue”
I'm going to go regular/low gain on both sides, as there's probably better pedals designed for higher gain sounds, and the KOT is known to excel at low to medium levels of gain, so it will be playing to its strengths.
I've no use for the 4 Jack option personally, as I run a very simple small board, and I imagine this option is for those who employ some kind of switching system on their board?
What's the consensus on having the buffer? If you have a pedal before and/or after it with a buffer, will a built-in buffer on the KOT be necessary?
Hope I'm not hijacking your thread completely @hotpickups but waiting for 2 years does mean I've changed my mind regarding the spec I'm going to order many times, and I don't wanna balls it up by missing something crucial...
With so many comparison web sites out there, how do I choose the best one?
I'm going to go with high gain on both sides as after reading the description on the site it's really the equivalent of just turning it up a couple of notches.
I like low powered pickups so a bit more range from the pedal seems good for me.
After thinking about it I'm going to go with the 4 jack option too - I don't have a switcher but I might want one at some point and there's no downside to having that option. Might also increase saleability later if switchers continue to be popular.
For those of you who have owned/played one, can I ask what's the difference between having the pedal set to overdrive (on the dip switches) and the gain set high, to having the pedal set to distortion (again, via the internal dip switches) and the gain knob lower?
Is this the same sound? Is the break up and ability to clean-up with your picking attack the same? Is the compression characteristics different? More bass cut on either setting?
I'm a low gain kinda guy, so I'm probably not going to go high gain red side, but would setting the pedal to distortion give me a high(er) gain overdrive sound if I ever wanted it?
My advice would be, pimp it out as much as you can - time again I think I’d maybe not opt for the buffer (since takes away battery power) but apart from that happy. You’ve waited so long, make it a one time purchase.
Having external switch is a massive thing, high gain makes a lot of sense - you can still get the low gain sounds but you have more (and more is always more!).
I think the question you’ve posed is difficult, overall you can get the same character with higher overdrive vs lower distortion - however there is (I feel) a slightly different compression and harmonic content - doubt you’d notice in real life tho
Ironically the standard colours seem to sell well but I’ve owned a blue and gold and they looked ace !
