Boss DD7 issue
RewqapRewqap Frets: 4
Hi guys,
I’m hoping someone can help me. I have a Boss DD7, circa 12 years old, that is causing me some issues.
When connected (even if it’s off) I’m getting some horrible crackling and popping noises coming through the amp. But it’s intermittent.  I’ve opened it up but couldn’t see anything obvious. Anyone have any idea what it could be? I’m guessing some sort of faulty connection/dry joint maybe?
Anyway, does anyone have any recommendations on where I could get it repaired?
Cheers
Nathan
  • ICBMICBM Frets: 72472
    Check that the jack nuts are tight. They can sometimes work loose, and the ground connection to the casing goes via the jacks.
