"Multi pedal Power supply" like "power supply for a multi-effects pedal"? Also a thing, although it's really only a power supply of the required voltage/amperage with the right connector.
Boss make great pedals, sound fantastic, built like a tank and reasonably priced.
- volts
- ma draw
- +ve or -ve pin
Then go find a power supply that has enough outputs of the required specs. You can daisy chain a few if need be, but some pedals will get noisy on a daisy chain.
Things like Cioks, OneSpot (the biggies not the chains), Voodoo Labs, etc. will usually have a mix of specific outputs and switchable ones. Be aware that cheaper units may not be isolated (can add noise) and posh ones are spendy.
Don't buy an expensive one unless you need to basically
In terms of a cost effective power supply, you'd struggle to find one elsewhere at this price with these features: https://www.thomann.de/gb/harley_benton_powerplant_iso_2_pro.htm?ref=search_prv_17
8 isolated outputs, 2 of which can supply more than 9 volts (12/18V). It also comes with a Y cable so you could link the 2 12V outputs together if you needed 24. If you did get something with a centre-positive power input, the converter cable will only cost you a few quid.
It really is excellent value, considering some of the big name ones are double or even triple that price.
https://www.thomann.de/gb/harley_benton_powerplant_junior.htm?sid=5bdf855f2492b6ab792a4142e7c4ce3b
