*OK the amp is a Matchless. but it's the principle that counts!
With a 2 channel amp and one pedal as a boost type thing you can easily get 4 sounds - clean, boosted with the pedal, channel 2 of the amp with some breakup and then pedal again for a lead sound. Even 1 channel, 1 pedal and use of the volume knob you can cover a wide range of gain. Usually easily enough for most gigs anyway.
Did feel quite liberating to not have to piss about with or worry about a whole board. Get a good core tone and just worry about playing.
Obviously depends on the type of gig/band situation though and for some gigs I’d feel lost without a whole board in front of me.
I may even institute doing the odd rehearsal sans fx as it is always good to be prepared for eventualities.
A couple of very memorable ones -
Arriving at a provided-backline gig and finding the promised "Fender Twin" was a (solid-state) Princeton Chorus - I used my Mesa V1 pedal into it and got one of the best tones I've ever had. I nearly went and bought a Princeton Chorus - I'm actually not quite sure why I didn't...
Arriving at an open mic where there was supposed to be an electric guitar amp, and finding that there wasn't one. DI'd my Rickenbacker straight into the PA and got a very nice electro-acoustic tone. It was so good I have now done this on purpose on several occasions.
The way I look at building a board or three for applications is what do I want and what options do I have? This obviously gives scope to buy more pedals.
My current home board has two over drives, two synths, a trem and a reverb/delay.
My current band board has an overdrive and delay.
Unless you are playing originals where the effects are integral to the song writing or a u2 tribute you won't need effects for all the songs. The question is what do I actually need?
I felt like I was tightrope walking naked, but it sounded surprisingly good (apart from the lack of all my swathes of ambience) and the only bit that sounded a bit duff was one where I have a loop of glissando guitar going over part of a song.
Not going to do it again though!
