Have you ever had an electric shock from an amp *after* you've unplugged it from the mains?
It's happened to me a couple of times now, with my Seymour Duncan Powerstage 170. Unplug from the mains, but accidentally touch the pins on the mains plug a few seconds later and BLAM! Shock all the way up my arm.
It's getting a bit disconcerting, if I'm honest. Don't want to have to return it, because it's a brilliant amp (aside from trying to kill me every now and then).
If the amp has an IEC cable, always unplug it at the amp end first. The pins inside the socket can then still give you a shock, but you're unlikely to touch them.
When you turn the amp off and keep playing, you still hear the amplified sound, slowly fading. With no power stored, the amp would be immediately silent.
The mains RF filter cap is fitted to most pieces of kit but the designers don't think peeps are going to grab the plug pins!
Sometimes the cap is post mains switch and so if you switch off there is no connection. The problem with that is if the cap shorts* it can weld the switch up!
As mentioned, hurts but not dangerous..Well, be careful if you have a pacemaker!
*These are special "X" or "Y" rated capacitors and can "self heal" i.e. they can short but recover, the shorted section is blown away.
Dave.
A small cap is the same deal .... a bigger cap like a reservoir capacitor used to smooth the DC supply IS capable of holding enough Joules of energy to kill you ...
If I'm working inside an amp that hasn't been discharged and I touch something I shouldn't the caps will discharge through me and I could die.
Why do I not die touching the plug pins? Am I not giving the charge in the caps exactly the same path to ground?
Even so, the shock from a spike suppressor is a lot more painful than a static shock because there is still more charge stored. But the main filter caps in an amp are a huge value by comparison - at least 100 times larger - and store easily enough charge to produce a lethal current for long enough to kill you.
Also, it's fine if the charge dissipates quickly, but for it to still be there 10 seconds later isn't good design IMO. Sure, I can unplug from the device first, but the bassist in our band picked the amp up (remember, it's only a small box) and accidentally got fingers near the mains socket and got the same shock when it shifted in the hand.
The only real preventative, I suppose, is to stop using the power switch on the amp and use the mains socket switch instead so the caps discharge instantly.
Voltage potential
Impedance of voltage potential
Amount of storage
To cause a serious shock it takes around 20 to 30mA of current for a certain length of time .... than means there needs to be a high enough voltage to push 30mA through the impedance of your skin and flesh, the voltage source needs to be a low enough impedance to source 30mA to achieve this and finally it needs to be able to supply 30mA for long enough for you to be harmed .... lets say 1 second instead of 10ms
So a small cap although charged to a high voltage isn't holding enough energy to do this ... in the same was the static charge stored on your jumper isn't either
Until very recently your average laptop contained much higher voltages than a valve amp ..... the inverter used to power the backlight gave out anything from 600 to 900V .... as laptop engineer for many years I had many a shock but no harm as the inverter couldn't supply enough energy if that makes sense. Bit like the HT circuit on a car, survived many a shock of a coil or distributor over the years working on cars .... that's thousands of volts
Would a healthy adult be able to stand mild levels that would other interrupt another heart?
Genuine question that entered my mind!
I've had a few shocks in my time, and this one definitely sits at the "hell of a jolt" end of things.
Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
It is perhaps worth mentioning that it actually takes a lot of electricity and for a long time to kill a person as they found out in a most horrible way with the first use of the electric chair!
What a short, sharp shock can do if it goes across your chest is put your heart into "fibrillation" a sort of non-effective fluttering I understand. You then die from the heart attack if help is not immediately to hand.
There also seems to be some confusion about the current needed to cause fib'? I was always told "Five mils kills".
There was a Mythbusters prog about the "heater in the bath" Bond incident and they started off looking for 40mA or so? Later they were advised that 5mA was the lethal current.
Re the cap across the mains. Sometimes a 1meg bleed resistor is fitted but,
1) That value still takes a second or two to discharge the cap.
2)Very high value resistors under constant high voltage stress have a habit of going O/C!
Dave.
