I’m thinking of getting my first valve amp when I have some more money because I feel my old solid state amp just can’t get the hendrix tones I’m after. I’ve heard hendrix used vox amps on the studio. What good vox amps is there under £600? I’m mostly a bedroom player so is an AC30 too loud or is it just an AC15 with more headroom?-and would the AC15 break up at bedroom volume? I’ve also heard fuzz face pedals don’t work well with the top boost channel and some amps like the AC10 or AC30s1 only have one channel that’s based on the top boost. My fuzz pedal is a Dunlop JDF2 (germanium fuzz) and my guitar is a fender strat (SSS).
If you're OK with a head rather than a combo, then the AC15CH head has a built in attenuator which goes down to 1/6W at it's quietest...you should be able to get a new one for £450 or thereabouts. I have one, it lives in my bedroom, and it sounds great! It's also a "proper" AC15 in that it has both a Normal and TB channel.
I've used a bunch of different fuzzes with mine, and don't recall having any major problems. Sometimes they work better with the Normal channel than the Top Boost, but that's no biggie...the Normal channel is voiced well, anyway. I've gt a DIY Si FF derivative that I built, and that sounds good. Tonebenders work extremely well, too.
Even the guitars he used varied - whilst he's most famously associated with the Fender Stratocaster, he also used a Gibson SG, Flying V and even (albeit rarer) a Les Paul. Interestingly he didn't start using Strats til 1966 and before then he used Epiphones and Danelectros.
Effects wise, the Dallas Arbiter Fuzzface, Vox Wah and UniVox Uni-Vibe (the speed of which he'd control with an expression pedal) were pretty much his staple effects - but he used others too including Marshall and Roger Mayer fuzz and Octavia units. But don't forget too that he used a long coiled guitar cable that cut the highs and so that was a very important part of his sound too.
I'm not trying to put you off buying a good valve amp, but unless you get one with an attenuator, for bedroom use you might have more success/fun with either a good modelling amp that can give you a wide range of different amp and effect emulations to get Hendrix tones, or a good mfx unit with amp modelling and effects to use either through headphones or in front of a valve amp, that will help you get good tones at bedroom volumes.
I’ve recently got the 2 x Blue version and now I have to buy a stadium to go with it
That will get you far closer than trying to do it with the ‘right’ gear at bedroom volume, which simply won’t really work.
The pedal is actually very good.
If you do want to do it with normal pedals and an amp, a good modelling amp will still probably work better than a valve amp for low volumes.
If you *must* have a valve amp and you’re set on a Vox, I would say the new AC10 actually sounds better at low volume than the AC15 - but an AC30CC or C still just sounds the best. It’s a bigger, fuller and more complex sound even at very low volume - the problem is the sheer size and weight of them.
soundcloud.com/thecolourbox-1
For example, amongst a load of others, I have a Blackstar HT1R.
This is a titchy little 1watt handbag with an 8" speaker, that if I have it on full volume with a bit of gain can easily annoy the neighbours & I live an old house with 30cm thick stone walls... just saying
Also, I do have a wah pedal and strat.
This isn't the most scientific test in the world but it's fairly accurate .
I'd probably get the Greenback, or a G12H-30 if you're looking for more of a Hendrix sound, or one of the modern Celestions like the V-Type.
Any of them will give a huge improvement in tone and volume. I know you probably don't need volume, but the stock speaker really is weak and makes the amp sound underpowered.
