Can you tell string guage by eye?
FuengiFuengi Frets: 2850
Got some strings to change on a new guitar, not sure if they are 9s 10s of 11s. I have a set of 9s and a set of 10s if I opened the 10s would I be able to tell by holding the E side by side if they are the same gauge?
Didn't want to open up the packet unless it's worth it.
  • tony99tony99 Frets: 7177
    I can but I had to learn.
    Bollocks you don't know Bono !!
  • Paul_CPaul_C Frets: 7903
    You'd be better off using the low E - there's a chance that a 9 might be nearer 9.5 and the same for a 10, but 42 or 46 would be much easier to decide on.
  • FuengiFuengi Frets: 2850
    I'm never sure if the low E is the vertically low e or the pitch low E?
    edited June 2019
    low note - the clue was the mention of 42 and 46
    which, now I think about it, was probably what you were thinking of in your first post - feel free to ignore me :)
  • BellycasterBellycaster Frets: 5879
    Didn't know you were a Geordie @Fuengi ;
    Only a Fool Would Say That.
    A cool trick for remembering is always to say 'low e' in a very, very deep voice
  • ICBMICBM Frets: 72912
    Which gauge would you want to use if there were no strings on it now?
    Use those.
  • underdogunderdog Frets: 8334
    I'm a body piercer by trade so am very good at eye measuring anything in very small increments, a 1mm difference in jewellery looks massive to me, so things like string gage I can usually see a difference quickly.
  • KittyfriskKittyfrisk Frets: 19257
    So am I every time I change strings...
  • sweepysweepy Frets: 4211
    With my eyes I can barely tell which guitar I pick up  ;)
    Use those.
    Isn't the nut cut for the string guage?
    Could I get my Ernie Balls pierced?
    edited June 2019
    4:2 ?
    4:2 ?
    Aye that should balance them out a bit
    If you mean is it cut to exactly the same width slots as the string gauge - no, not if it’s been done properly.
    Have put some 10s on it, it seems ok.
    It's a Modern Player Mustang, one of the Chinese jobs. What a bitch they are to restring! The bar is so low I had to wedge a screwdriver under it to get the low E underneath.
    Is it worth upgrading the bridge and vibrato on these anyone know?
    You can use the arm to rock the bar forward, or adjust it up slightly if it’s too low.
  • MusicwolfMusicwolf Frets: 3713
    If I don't know the string gauge (i.e it's someone else's guitar) then I use a digital Vernier gauge to measure the low E.  I've tried measuring the high E and it's really difficult to tell say a 10 from a 9 so it will be the same trying to do it by eye.
    On my own guitars I record the gauge on the back of the headstock (although I can tell by playing them).  At the moment all but one of the electrics seems to be on 9s.
  • richardhomerrichardhomer Frets: 24863
    ‘Gauge’
    I also kept trying to spell it guage.  Thank god for spell chequers =)
