Not yet no. I don't have much knocking around at the moment in terms of drivey pedals. Just the Fallout Cloud, which does sound mega on bass actually.
I have a dave hall preamp with a boost and a valve in it which gives super saturation. Don’t make em anymore but you’re welcome to borrow mine to try the theory if you want.
It's bloody fantastic.
There is also the DG AO Head, but I don't like that one. It's actually more filthy but it's not tight or defined enough for me.
The preamp in the M900 is based on the B3K V2 but tweaked for the amp itself.
I've got a Mk1 and I'm really close to splooging on a Mk2 as well.
If you want a pedal - then the EBS "Billy Sheehan Ultimate" will do super saturated and defined. It's not just a Billy type drive, it's a lot more versatile than that. It's very differently voiced to DG stuff.
If you want cheap. Boss LS-2 pedal + EHX Metal Muff in 1 loop and a good compressor in the other to match the compression of the driven side so the clean and dirty notes die at the same rate.
https://soundcloud.com/drewb2015/ampeg-b15n-test
Here is the preset:
Using the VMT option on the drive. So I'm assuming the VMTD pedal wouldn't have any trouble
It was very good but a bit of a 1 trick pony for me. It also seemed very sensitive to string choice - with my preferred D'addario's there was a high overtone I didn't like
@fretmeister
https://neuraldsp.com/products/parallax/
