Meaning I could probably slap some v30's in mine and call it a day?
What do do first is try two, in a 'x' pattern (top one side, bottom the other) - that's what Bogner's 'Uberschall' cab has, and is thought to be one of the best speaker combinations for heavier tones. OK the Marshall cab isn't as heavily-built as the Bogner so it won't sound exactly the same, but it will be closer than what you have now. If that fails, buy another two V30s.
My Egnater is nicer than my Marshall. Think a speaker change might be in order.
Both my cabs are angled. I do fancy a new cab
The smaller cabs are almost all MDF from about the start of the JCM900 series, although the 1936 2x12" has fairly recently returned to being ply (not sure about the back). Some early 900s are ply.
Yeah I was dubious as well but it really is like the V30 and T75’s each cancel out the bad aspects of each other. Works well for clean, but under gain it’s very, very good indeed
• Youtube - https://www.youtube.com/@Goldeneraguitars
The quality of the wiring and the impedance switching PCB is a bit questionable too - I've rewired quite a few with all-soldered connections and standard jacks in parallel, largely for safety reasons since the switching going faulty is quite common and can be a cause of blown amp transformers, and they always seem to sound better afterwards as well... which may or may not be confirmation bias .
But there may be a genuine reason - the switching system puts the speakers in series-parallel in 16-ohm mode, because each pair of speakers is wired in parallel for 8 ohms. In vintage cabs and as I would rewire one, they're parallel-series with each pair of speakers in series. There is a real difference, caused by the change in damping factor.
Probably not worth bothering too much since it's a 'modern' cab even if it's twenty years old, and the year has no bearing on value or sound really.
