How to fit a pick guard on a Les Paul without screws
RaymondLinRaymondLin Frets: 12003
my Les Paul have no pickguard, or finger rest, whatever it’s called.  But I like it put one on except I don’t have to drill holes in the guitar in case I change my mind...are there any products out there that you can clip on the pickguard and clip off?
  • Philly_QPhilly_Q Frets: 23393
    Chewing gum?
  • SteveRobinsonSteveRobinson Frets: 7091
    edited June 2019 tFB Trader
    Didn't the 2015 Les Paul guitars have a pickguard that clipped to special pickup rings? Maybe they are available as aftermarket items?
  • underdogunderdog Frets: 8334
    The 2015 ones came with a screw less pickguard, so you'd need pickup ring from that and a pickguard.
  • richardhomerrichardhomer Frets: 24862
    edited June 2019
    Philly_Q said:
    Chewing gum?
    Facetious! ‘Nails’ is the the correct answer....
  • ICBMICBM Frets: 72846
    Easy - fit it in the case where it belongs.
    Or better still in an envelope after you've sold it on Ebay.
    1reaction image LOL 0reaction image Wow! 3reaction image Wisdom
  • RaymondLinRaymondLin Frets: 12003
    Not a fan of the look then?
    No, nor the clicking and creaking noises they can make when you hit them with your pick or rest your fingers on them. The layered black ones on a Custom aren't quite so bad, but the cream ones just look cheap and nasty.
    And remember that every Les Paul ever made is even heavier with one on :).
  • TTBZTTBZ Frets: 2927
    They fit in the bin quite easily :)
  • tony99tony99 Frets: 7169
    A les paul without its pickguard is like Godley without Oates.
    Bollocks you don't know Bono !!
  • Winny_PoohWinny_Pooh Frets: 7842
    You can make little metal L brackets that glue to the side of the pickup rings and bottom of the gaurd. Do it with the gaurd & rings off the guitar of course.
  • Calum13Calum13 Frets: 37
    Sticky tape
  • bodhibodhi Frets: 1334
    And in case your neck pickup keeps falling out.
