This is probably nothing and I'm being paranoid. But I thought I'd ask anyway.
So I've got a new MK2 HT-5 head and when I switch it on there's a faint crackle/buzz with a slight high pitched whistle that comes from the head itself all the time it is on. It's really quiet, and easily drowned out by even relatively quiet playing. But I do find the slight whistle a bit annoying, even though it's on the edge of hearing.
But I wonder if it is the sign of a problem somewhere?
The sound isn't coming from the speaker. And is still there if I run the amp with no speaker. It doesn't get louder when I change any controls. And as I said it's fairly quiet, but noticeable when I'm not playing.
EDIT - Sound coming from over by either the power valve or output transformer.
I've owned some very noisy amps in my time so I don't know why this thing is bothering me. But the HT5 is otherwise ridiculously quiet, so did wonder if this whistle was a sign of a potential problem.
FML
Its a Mk2... Slightly different.
Grumpyrocker, if you can’t get it sorted, pm me.
I do have a multimeter so I may have a crack at it. Though MK2 data not easy to come by. Unless power section is same as MK1. It does have a bias adjust and balance adjust.
So I'm going to have to take it in to my nearest Blackstar place and get them to do it. My eyes (and hands) aren't up to it.
Best to know one's own limits. I'm not very dexterous.
Just bought a new HT5R MK2 head this week with the same problem as you described here, pretty annoying for a practice amp.
In comparison with the HT5R from the previous version the whistle from power of this new unit is 2 or 3 times higher, when I turn the MK2 on (nothing plugged) I can ear it in all the room when not playing, or even when playing cleans at low volume.
Was your problem solved by replacing the power tube and adjusting bias?
If yes, do you recommend some specific model/brand?
Thank you
Send it back to the shop you bought it from.
