Help me choose pickups
RolandRoland Frets: 8809
Having spent several years developing my perfect Telecaster I played with another band last week, and I need a different sound. Current band has second guitarist, keys and sax. My tone with them is bright, and designed to leave space for these instruments. Last week it was just bass and drums, and I need something with a much fuller sound. This is an opportunity to make another guitar, but what pickups to put in it?
My “perfect” Tele has a Strat style neck pickup (Oil City Californian) and a tapped bridge (Wapping Wharf). This means I can have five sounds: full bridge, tapped bridge, tapped bridge and neck in parallel, neck, and both on series. My first thought is to get similar switching using a tapped bridge humbucker and soapbar P90 neck. I know that @ICBM likes the Oil City Brass knuckle. I like the idea of a P90 because it will be fuller than a single coil, but retain better clarity than a humbucker. I prefer a soapbar to a dog ear so that I can adjust the height.
So go on, spend my money for me.
  • FunkfingersFunkfingers Frets: 14646
    Stick with your existing pickups. Use a midrange booster pedal of some sort.
  • Stick with your existing pickups. Use a midrange booster pedal of some sort.
    Did you miss this bit?
    "This is an opportunity to make another guitar, but what pickups to put in it?"
    :-D
    Yes. It is greyed out.
  • breezytelebreezytele Frets: 273
    edited June 2019
    Matt at Montys now does Brinsley’s  5 way tele switching which might be of interest (and might be what you’re describing)
    Analogman does the ‘Big T’ pick ups and the neck in particular might really suit
    Also, they’re made by Lindy Fralin
    https://www.buyanalogman.com/Analog_Man_Jim_Weider_Big_T_Telecaster_neck_pickup_p/am-bigtpickup.htm
  • SteveRobinsonSteveRobinson Frets: 7091
    One of my Teles has a Texas Special in the bridge and a Gibson mini humbucker in the pickguard. It sounds huge.
  • Winny_PoohWinny_Pooh Frets: 7845
    I'd use an alnico ii 4 conductor bridge humbucker and wire it to a 500k pot so you can gradually roll off one coil to ground. I have this setup on my 330 and it's the best sounding and most versatile bridge pup on any of my electrics.
  • RolandRoland Frets: 8809
    Having spent several years developing a focused sound which leaves space for other instruments I now want more of a soundscape filler. I’ve already got the capability to play around with EQ and boosts with my AxeFX. What I want is source texture rather than processing.
    Gas doesn’t go away, it just changes it’s nature. However on this occasion I might marmalise an existing guitar.
    I’ll use a superswitch because, with new pickups, I’ll want to try out different combinations.
  • digitalscreamdigitalscream Frets: 26951
    edited June 2019
    If you want humbucker-fullness but the clarity and attack of a single coil, then in my opinion you can't do better than a Red Lace Sensor in the bridge and a Blue in the neck.
    Next option for that sort of thing would be a pair of SD Little '59s.
    <space for hire>
  • p90foolp90fool Frets: 31779
    If you can't get an AxeFX to give your Tele a big enough sound to drive a 3-piece the problem is not down to pickups.
    I totally understand where you're coming from in terms of tone and in my analogue case I fix it with a pedal, but the relative subtlety of a pickup swap would not have been enough.
    @p90fool ;Because to want to build a new guitar, this time with a humbucker and P90.
    Fair play, definitely worth doing then
  • RabsRabs Frets: 2620
    Get a humbucker sized P90...  That way if you change your mind you can go full hummer later without any issues..
    I REALLY love the Vanson humbucker sized P90.. Used them on a few builds and always loved the way they sound. They are cheap but really good ( I always use PIO caps for what its worth ).
    https://www.ebay.co.uk/itm/NEW-Vanson-AlNiCo-V-P90-Humbucker-size-Single-Coil-Pickup-HB90-Neck-or-Bridge/121200644356?hash=item1c381f1104:m:m_R8-qUdWVqHr-E-qgOPaQQ
    Heres a sound example
  • FatfredFatfred Frets: 7
    My recommendation would be for the Seymour Duncan P-rails with the Triple Shot switching system.
    You have the best of all worlds in terms of coil tapping, parallel/series (much more useful than coil tapping IMHO).
    You can have single coil Fendery sounds by using the blade, P90 sounds by using the ....P90, parallel or series 'bucker sounds or any combination thereof.
    I have a pair of them in a Vintage VS6 SG copy and they are truly brilliant.
