a simple job (changing a celling light) that wasn't so simple (for me)
markblackmarkblack Frets: 1591
I've pretty much decided I've reached the end of my limited knowledge and need an electrician...
But I'm still curious to see how this work.
I took down a ceiling light, forgot to take a picture of how it was wired and messed it up, I now have three rooms without light's :)
When I took it down there were four cables running into the rose.
What I have is:
A neutral wire (marked with tape) so I assume that's the switch cable.
5 red wires (two if these goes to the switch)
3 neutral wires
5 earth wires
Unless someone on here can tell me it's a simple job, like a said I'll get an electrician in. But again as I said I'm just curios to know how it all works.
Any suggestions much appreciated.
Many thanks
Mark
  • rossyamaharossyamaha Frets: 2440
    I did the same thing. It’s on a loop. Get a sparky in.
  • FunkfingersFunkfingers Frets: 14415
    Have you got a switching system in which, say, the hallway light can be switched at either end of the hall? Those tend to complicate matters.
  • boogiemanboogieman Frets: 12352
    edited July 2019
    What you have is called three plate wiring , there’s plenty of advice and wiring diagrams available if you google it.
    Basically you put all the lives (red wires ) together into one terminal of the rose. The unmarked neutrals (black wires) go together into another. The marked neutral, which you’ve correctly said is your switch wire, goes into a third, on its own. All the earths go together into another. Your lamp holder is then fed from the neutrals and the switch wire. It’s not a difficult job.
  • spark240spark240 Frets: 2083
    edited July 2019
    What room is it in....and did that light switch on its own or was another switches with it.....
    No need to pay a Spark....we can work this out.
    Are you sure 2 reds go to the switch?....and are those 2 reds inside one grey cable?
    Mac Mini M1
    Presonus Studio One V5
     https://twitter.com/spark240
    Reddit r/newmusicreview
    edited July 2019
    Im not convinced the taped Black is the switch wire...hes said he's got 2 reds going to the switch which suggests a twin red as live and switch wire, plus he's got more reds than blacks,
    Mac Mini M1
    It does sound odd. I can’t figure out why there’s four cables going in but there are five reds and earths.  :/
  • markblackmarkblack Frets: 1591
    Cheer @spark240 @boogieman @Funkfingers for the advice - maybe this is a bit clearer?
    Here's a couple more pics - just a standard switch in the room.
    Cheers
    Mark
    edited July 2019
    Ok, so heres what I would do....as Im not sure why that black is marked with tape...
    Leave that twin cable out for now ( and see art doesn't work)..
    The other 2 red / Black are the L&N in and out, so put the 2 reds in a same terminal, and the 2 backs in the Neutral terminal .
    The twin red is your switch as you know, so 1 of this reds goes in with the other 2 ( in spare terminal ) this will send alive down to your switch, the return red ( the switch wire) then goes into the Live terminal i  the rose, this will connect to the Brown of your lamp.
    Do that first.
    Just one light in the room yes ?
    Mac Mini M1
    edited July 2019
    @spark240 cheers for that. Yes just a one light in the room.
    I'll give it a go.
  • tony99tony99 Frets: 7104
    I'm not sure how much help but on the middle two pics the wires and things kind of look like a little hermit crab, with his eyes and a couple of little feelers just popping out the sand, checking the coast is clear before he goes about his day.
    Bollocks you don't know Bono !!
    8reaction image LOL 0reaction image Wow! 0reaction image Wisdom
    edited July 2019
    @spark240 ;;
    Tried your suggestion but no joy.
    Put all earth wires in one junction box.
    Put the two neutral wires in one junction box - the added the neutral of the light fitting to those two.
    Put the two live wires into one junction box.
    The I linked one of the switch wires to the light. And the other switch wire to the other live wires. (I did this both ways)
    No power to the light (or any of the hall lights)
    I did the current tester on the wires while I had the power on and the only red wire with power is the one that has the black wire with tape on it as its partner. (pic attached)
    I'm sure you've got better things to do with your Sunday than answer my questions so feel free to ignore this!
    Cheers
    Mark
    incase its simpler this is what I have
    All sorted now :) didn't see the crab, now I've removed him it's like daylight!
    Ok...so out of interest, when its connected as is now...do you have a live cable at the switch?
    Mac Mini M1
    Forget that....just noticed what you said.
    Ok....so ...Im not happy with this but.....put the red you know to be live in with the other 2 in the spare terminal, and put the taped black in with the neutrals....I assume you do you have MCB;s in the fuseboard and not off fusewrie...as this may just ....
    Mac Mini M1
    @spark240 dropped you a PM. Ta.
  • BarneyBarney Frets: 615
    edited July 2019
    It's the black with the tape on that is throwing things a bit ....It could even be just a nicked cable with tape on and is a neutral ...assuming it is that
    You would need to put all reds in a connector block ...apart from one of the reds from the switch which is the cable with the 2 reds in
    Put all the blacks together a connector on there own
    All the earths together on there own
    And the red from the switch...the one left on its own in it's own connector
    The lampholder put the brown to the single red  and the blue to the neutrals..that's the blacks
    Its possible the switch might be upside down ...off it is turn the switch the other way on
  • Simon_MSimon_M Frets: 542
    It’s 3 plate wired. Identify the switched live by using a multimeter/test lamps and flicking the light switch off/on. This may be red or black depending who wired it. Connect that to you your light’s live. Connect all remaining black cables together. Connect all reds together. Connect all earths together.
    Job’s a good’un.
    @Barney @Simon_M @spark240 Cheers lads!
    Got it sorted. The wire with the tape on it threw me, most forums say thats how you mark the switch live wire... guess the guy who did mine had other ideas.
    As you all said I this is how I got it working.
    Cheers
    Mark
    Let there be light ....
    Mac Mini M1
  • Paul_CPaul_C Frets: 7756
    You did better than me on my last attempt - to the best of my knowledge I wired everything up correctly (but as you'll see, clearly not) having (thought I had) noted where everything went, but when I turned the light on it blew everything in the house.
    As it was 9pm and I was in the dark I called out an emergency sparky who replaced a huge fuse in the meter box (I didn't even know there was one in there) and wired my light up correctly.
