You know that sound you get when you have a slightly noisy valve? Like a quiet soft crackly sound, or slight static. Not really a problem but slightly annoying and perhaps an indicator that a valve might need replacing at some point.
Marshall Origin 20w head. Swapped out all three 12AX7s, noise still there. Swapped out each EL34 one at a time (I only have one spare) and noise still there.
Either it's both EL34s or something else. Put De-oxit in the valve sockets and reseated.
Not a critical problem, just curious as to what else to check.
The plate resistors are the large beige-coloured ones, which look like they may be carbon-comp - unlike the blues ones which are modern carbon-film and the larger grey ones which are wirewound.
Ironically a cathode-biased amp with separate resistors is the least sensitive to mismatching since each valve self-biases itself independently... but that doesn't help you here .
Do you think they're compensating for good design practice being to run a power component at no more than half its rating?
Just to set the record straight!
Blackstar used carbon comp Rs in the Artisan series only (and even then, dropper/decouplers were metal film) . The reason being the "cache" that has grown up around them* . The techdirect was never happy about it since you are technically using old, less reliable technology and charging a good wedge for it!
Have to say I never had one fail.
*Yes CCs ARE less linear than MF but you have to hit them with 100V + to measure even a tiny amount of distortion. Not likely to be heard in a guitar amp.
Dave.
