I've got custom Tweed based 1x12 combo that I'm searching for the right speaker for. The amp is based on a single ended tweed champ with a 6SN7 in the preamp. I use it at home with a combination of power scaling and a Swart night light jr. It sounds fantastic but I'm looking for the perfect speaker to finish it off.
I've tried a Greenback in it that was too stiff and barks and makes everything sound too much like a Marshall. Right now I've got an Eminence Jet City branded speaker that is better - less brittle, softer attack and less efficient so I don't need to attenuate as much at home. However It's not a very complex sounding speaker and lacks some lower mids and thickness.
Due to the layout of the chassis in the cab I can't fit an alnico speaker in there sadly.
Any suggestions?
Cheers
Al
So long as you don’t need lots of top end sparkle then I think this is a great speaker.
the C-Rex is actually pretty even sounding once it is well and truly broken in. Still takes some of the presence of a really bright amp though. Definitely dark out of the box! Took at least 6 months if not a year of gigging and practices to get mine as sweet as it is now...
