Vox Ac15 C1 - valve problem (I think)
easter12easter12 Frets: 0
My AC15 C1 has started to crackle when I first turn it on.
The crackling sound stops after 10/15 seconds and then the amp is absolutely fine.
Has anyone ever had the same problem?
I'm not technically great with amps but a few friends have said it might be the valves.
The power/output valves maybe?
Any advice?
Here's a quick youtube vid of the sound it makes when i turn the amp on:
https://youtu.be/FEdEkPaWT4M
Thanks for any help :)
  • ICBMICBM Frets: 72404
    Hard to tell, but a valve is a possibility - not necessarily power, and not necessarily faulty but possibly making a poor contact with the socket.
    Does it do the same if you use the standby switch on power-up and then switch to fully on, or not? Does it do it if you later put the amp on standby, wait a few minutes, then back to fully on?
  • ecc83ecc83 Frets: 1636
    "We" had a batch of EL84s that made a quiet "rustling" sound for 20 secs to a minute at switch on. After a few on/off cycles they stopped doing it. I just left the amps on all day and then next day they were fine. The next batch of valves didn't do it as I recall.
    Modern valves are ***t you see.
    Dave.
  • easter12easter12 Frets: 0
    Yeah it does still do it when I put it on Standby first and then put it fully on. It's not as loud though. Would that be significant? Thanks for your help
  • PhiltrePhiltre Frets: 4173
    Dave.
    JJ's?
    Dave.
    Thanks for your input :) I can try leaving the amp on for a good few hours and then see if that makes a difference. I have used it in the past though so it's not like the valves have not been used for long periods of time.
