Fuzz Face kits, where to buy?
joeyowenjoeyowen Frets: 4025
Has anyone ever purchased a Fuzz Face kit from somewhere they can recommend?  I don't need the enclosure, but need everything else!
  • TateFXTateFX Frets: 114
    Can't go wrong with fuzz dog, I'm actually making one for my self at the moment
    Formerly Stu_Tate
    Tate FX
    www.TateFX.co.uk
    Instagram
    I had a look at them, guess I'll go with them!
    Ts dude
  • robertyroberty Frets: 10893
    The mini ones are very fiddly. Doable if you follow the fuzz pup assembly instructions which are separate. Normal sized enclosure is a lot easier. I went silicone NPN and put in the recommended smoothing caps to start with but ended up clipping them both off. Good luck :)
  • SassafrasSassafras Frets: 30273
    Pigeon FX.
  • Fuzz dog. Try the axis fuzz!
  • BeardyAndyBeardyAndy Frets: 716
    +1 for Fuzz Dog
    I managed to lose a bit and solder a couple of caps in the wrong way round and they sent out some spares foc.
    +1 for Fuzz Dog
    I remember being a fuzzdog customer very early doors maybe 2012 ish and I messed up an Distortion plus by lifting a pad. Lee was so helpful in what to do about it. That pedals still gigging today with no issues.
    Formerly Stu_Tate
    Tate FX
    www.TateFX.co.uk
    Instagram
    Well thanks all for the great advice! I listened well and ordered from.... China.
    Not even kidding.
    I've read by a few that they can be tricky, and it will be my first build.  Figured a will do it on the cheap, and if I succeed, I'll try again with the Fuzz Dog version.   I did go to order from Fuzz Dog, but they were out of stock doh!
    Hopefully I'll succeed, and then order a proper kit.
    Until then, wish me luck
    Not even kidding.
    what did you order - a kit or bits ?  and from whom ?
    At that price it won't be real AC128s, a real 1590B enclosure, real pots, a real circuit board or a real foot switch.
    Apart from that it all looks pretty good.
    That's fine, I'm not a real pedal builder haha
    I've got some bits I'll use but yeah, practice run for me. I'm excited
    The fuzz face is one of the simplest builds so, yes, it's a good introduction to pedal building.
    Im potentially  shopping for a king tone ge mini fuzz has anyone a build in the same vein ?
    Adjustable bias , bass control etc
  • OctafishOctafish Frets: 1937
    Those transistors look like generic repro AC 128s. Usually genuine 128s come in thin/tall cans rather than the short fat ones. Still should be able to make a good fuzz though and you can message around with caps values to alter the tone a bit.
