12 string to 6 if use heavier gauges?
AjotenAjoten Frets: 7
As someone who likes a wide neck but can't find them, I was wondering if restringing a 12er would work IF you put terrifyingly heavy strings on to increase the tension.( I guess a bit of nut notch faffing might be required too.)
  • crunchmancrunchman Frets: 11462
    Probably more a matter of adjusting the truss rod.  Slacken it off a bit and it should be ok without heavy strings.
    Depends what style of guitar you are after.  Assuming you are talking electric as this isn't in the Acoustics section, for a Gibson style, the 2015 guitars had wider nuts, which is one of reasons most don't like them.  They aren't 12 string wide but might be worth a try, and are normally cheap second hand.  If that's not wide enough, it will get difficult.
    If you are after Fender style bolt on, then Warmoth do some necks with a 1 7/8" width.
  • AjotenAjoten Frets: 7
    Electric, yes. Currently I have gypsy jazz guitar with a wobbly clip-in pickup and a 45mm nut (wouldn't want anything narrower).
    I assume these Warmoth ones fit a standard Strat neck pocket but also that only official Fender brands will have that pocket. A Strat copy I had was completely different.
  • boogiemanboogieman Frets: 12389
    I used a 12 string acoustic with only 6 strings for donkeys years, basically because I had it already but couldn’t afford another guitar. No need to worry about heavier strings, a truss rod adjustment will sort things out.
  • steamabacussteamabacus Frets: 1266
    Another player who likes a wide neck is John Etheridge - his signature Fret King guitar also has a 45mm nut width.
  • SassafrasSassafras Frets: 30301
    I've done that several times. Never needed more than a truss rod tweak.
