Hi 4-cable-methodists!
Do you use anything to keep cables together to create a sort of multicore arrangement?
I've been looking at various neoprene sleeves on Amazon, but not sure if they coil up nicely to go in a gig bag or flight case?
Something like this:
Meersee 3M Cable Management Sleeve Neoprene Flexible Cable Cover Sleeve Reusable Cable Tidy Cord Cover Wire Organizer
https://www.amazon.co.uk/dp/B073RHL84X/ref=cm_sw_r_cp_apa_i_ZojmDbMST5RJFAnyone have any experience? Or alternative ideas? I want to avoid spiky cable ties every 6"!
https://i.imgur.com/33U6app.jpg
I quite liked the idea of everything enclosed in the neoprene, though.
Maybe I should be the guinea pig and let you guys know!
https://www.amazon.co.uk/Cable-Tidy-Kit-Meters-Wrapping/dp/B079Y6H95B/ref=sr_1_20?keywords=Cable+tidy&qid=1563468883&s=gateway&sr=8-20
Really fiddly to get on, but works well once on and cables will still curl up nicely for packing.
Do they crack if you stand on them?
Eqd Speaker Cranker clone
Question about the braided sleeving, how do you get 4 x 3m of thick rubber cables with jacks on them through the sleeving?
R.
Worth mentioning- as it expands the sleeving gets shorter, so depending on how many cables you want to bundle and how much cable you want exposed at each end, order accordingly. I bought 6m of sleeving for 6m cables and ended up with probably 30-50cm of cable exposed at either end.
Do not use any sort of tape with a sticky side, it's a nightmare!
pedalsnake.com
Asking for a friend...
R.
Out of interest, which size braid did you use for three cables?
R.
