I move my pedals all the time, on an almost daily basis, so I went back to hook and loop.
I find the heavy duty Velcro is perfect. In my experience it holds the pedals just as well as dual lock but it’s much easier to remove pedals. Gotta be the proper Velcro though.
Even the smallest amounts of dual lock on pedals would on occasion, leave my fingers in bits.
I put full-length 25mm wide Dual Lock on the board. Pedals get two pieces on, which are the 25mm strip cut usually into thirds length-wise. Strymon-type things get four small squares or small strips.
Grips fine and can still hold the board upside down with nothing falling off, and they come off easy enough as well.
Think there's two types of D/L with different numbers of sticky-up things and grip levels, so guess you have to be consistent buying it.
Watch the parking meters
Dual lock across the top only - then it's easy to "peel" pedals off but they won't shift. A bit of velcro at the bottom for stability.
