Most every recommendation says to learn the pentatonic scales first. "Memorise them and you can join in with your buddies". Ok, I've been doing that but I haven't found a single video that tells me how to bridge that gap. Every beginner vid shows the teacher going through the scales then jumps straight to them playing solos. The best analogy I can think of is going online to learn to drive. "Here's the steering wheel, here's the pedals", cut to the guy driving down the road, "once you know them you can drive anywhere with your mates".
I would appreciate any advice or links to fill in that space.
I spose every teacher is different but I prefer not to let my students use the pentatonic scale or classic box shapes to begin with. I believe it hampers progress in the long run as it doesn't help the learner grasp the difference in maj & minor tonality.
A better way to do it is
Learn where the notes are all over the guitar.
Learn the intervals between notes that make up the major, minor scales so you can stay in key when playing with others or backing tracks etc
Once you know what notes you can use for any given key you can build solo's quite easily but your understanding of intervals will make your note choice more melodic and relevant to the chords behind rather than blindly banging away in a pentatonic box position like so many do
It's always good to work to a backing track ...you can easily play a full solo on 2 strings by altering dynamics ..note choice ...timing ..you could look at them as disadvantage exercises to make you think ...also it seems to connect the brain/fingers to the sounds quicker
The way you take the scales and connect them to music is through transcription- learning pieces of music from recordings and writing them down and then analysing them.
This also helps develop your ear.
They don't have to be written down using standard notation, although that is preferable.
The main thing is to understand how a player used a technique/run/harmonic sequence and why they used it.
Was it intentional, was it outlining the harmonic structure in melody, or was it 'outside' that. Was it an accident, or was it deliberate? (mostly the latter).
Once you understand that from a bunch of players you tend to have an understanding of how you can put it together in a way that makes musical sense.
Try spending the next month learning 2-4 bar phrases from two artists who make music noises that you like.
Learn at least 5 licks per player.
Then learn the chord progression that those licks go over.
At that point come back to this thread with any questions (feel free to ask sooner too, if you want).
It can take a while- years really- but it is related to how you practice, rather than how much you practice.
You could endlessly noodle on the guitar without ever thinking about it and never achieve the goal.
Deliberate, slow and mindful is what sorts this problem.
I'm not saying that you 'can't play' if you can't/didn't do what I've outlined above- but it is certainly the most efficient way to level up your playing and I think it is the most rewarding.
I will use the box positions however not across 2 octaves. Instead I will break up the scale and get them to focus on small phrases using 5 notes or so. Then expand by broadening the shape and combining positions etc. As long as they know where the root notes are on the fretboard it works alright.
I’m not speaking as a guitar teacher, but I think I’d want to be developing my students’ ear for melody and helping them work out how to play the tunes they love, alongside any harmony work and scales / arps practice. Actively listening to and transcribing melody in my view forms the basis for interesting, tuneful solo-writing. I think this is aligned with octatonic’s, jellyrole’s and others’ approaches.
Scales-practice on its own is great for developing technique and understanding of musical constructs, but not for developing the artistry of musicality. In fact if not supported with other approaches I would think scales-practice can be a hindrance and ultimately a constraint.
It is just one tool in the toolbox.
You can't built a house with just a hammer.
Very lucky not to get the jazz.
This.
https://www.justinguitar.com/guitar-lessons/the-blues-language-bl-401
https://www.justinguitar.com/guitar-lessons/minor-pentatonic-pattern-1-bl-402
https://www.justinguitar.com/guitar-lessons/bending-technique-in-blues-bl-403
https://www.justinguitar.com/guitar-lessons/5-blues-licks-from-pattern-1-bl-404
https://www.justinguitar.com/guitar-lessons/blues-vibrato-bl-405
https://www.justinguitar.com/guitar-lessons/using-blues-licks-effectively-bl-406
THen just follow on from there.
