Bit of a long story but I’m after some kind of small bore, 10mm or so, in-line hose fitting that can “tell” when there is water present in the pipe and send an electrical signal off to a relay to turn other circuits on, either via a relay or some other secondary switch.
I’m basically trying to prevent a water heater element from burning out when the tank in which it is placed is empty.
If the cold water feed to the tank is full then it can safely be assumed that the tank is also full. For space and practical reasons a float switch can’t be used. Ideally I need something small and robust.
I’m not sure there’s much pressure in the system so a pressure switch might not be suitable.
Does such a thing exist?
Thanks in advance.
Turns out there is an H in Haych! ~ Sporky
Bit of trading feedback here.
I have one that used a spring-loaded switch on the bottom of the tank - a bit flakier I think
Nil Satis Nisi Optimum
I don’t think I’ve ever come across one in a small pipe fitting form, though.
However, depending on the application, a water sensor is very simple to make. Two conductive probes spaced apart and connected to the +/- terminals of a sensor circuit (you could use a Raspberry Pi or something). When there is water between the terminals it will close the circuit and you can trigger whatever event you want. When there is not water then it will be open circuit.
http://www.kemo-electronic.de/en/House/Garden/M158-Water-Switch-9-12-V-DC.php
Your find it on CPC for about £15
