Just got an SG and am trying to set it up but noticing some difference in sound and playability and can't make up my mind what I prefer. It's an SG with a fairly shallow neck so the tailpiece can be screwed all the way down and the strings won't touch the back of the bridge.
Setup as low as it goes: more string tension, brighter sound, focused mostly in the high-mids and trebles. Good sustain
Raised up 2 whole turns: less spring tension, sound is growlier and deeper, less focus on the highs, the acoustic sound has lowered, it's not as loud but plugged in I think I notice more sustain due to resonance. The tailpiece raised allows more natural resonance in the metal parts, as if it was getting squeezed out before. Sounds more like a Les Paul now, whereas before it was more punchy like an SG should be. Went back a few times last night and settled on the full turns up for now.
What are your preferences? I tried to look up setups from pros, all I know is slash raises his tailpiece but can't find much info on the rest, and screwing the tailpiece as low as it will go without the strings touching the back doesn't apply in my case, they won't touch them. I assume having a Lyre Maestro Tremolo will raise the strings up a bit too?
I have 2 other Les Pauls, one has a pretty severe neck angle, the bridge really needs to be raised a lot to have low action. I raised the tailpiece so the strings don't touch and noticed a fuller sound, left it like that.
On my other, I have a Bigsby and the angle is very severe, the strings touch the back of the bridge, and not just lightly but I can't change the bigsby angle so that has to stay like that. The guitar sounds and plays great.
So I have 3 guitars with 3 different settings? Anyone here not screw it all the way down?
If you have a Bigsby on a guitar with a bridge that's too high to allow the strings to clear the back of the bridge, that will almost certainly cause tuning problems as well as excessive force on the bridge when you use the Bigsby - you need one of these:
https://bricksbiggsfix.com
It stays in tune fine and sounds great, but there is just no way for the strings to clear the bridge as the bigsby bar is pretty close. The reason I think it stays in tune fine is that the bigsby is not so responsive, I'm not affecting the string very much when I even go crazy on the bar so there is just not much movement there. I'm sure it would be better if there was, so I will probably have to get this.
