A good friend, who is also an excellent drummer BTW, told me that there is a plan to 'develope' a major Solar Farm very close to his house. Amazingly, but unsurprisingly, the developers have not held any information seminars or even discussed it with the locals in the area. So I am asking any of you who live close to a Solar Farm to contact me (privately if you prefer) with your observations. Issues such as noise, how it affects wildlife etc. In short anything that you think is important for people, who will be living beside these Farms, to be aware of.
Thanks.
Nil Satis Nisi Optimum
I don't see why they would be a problem? They are just soaking up sunshine, and that's what every arable crop does.
Feedback
Falls into the obvious aging trap. Again.
Stage 1: Anything that exists when we are born is normal.
Stage 2: Anything developed when we are between 10 and 50 is exciting and new
Stage 3: Anything invented after we turn 50 is against nature and humanity and needs to be stopped before we fall into a black hole.
My feedback thread is here.
2: Less damage to wildlife than a coal plant
3: Less chance of a nuclear escape than a nuclear plant. Zero in fact.
4: Fewer profits if you own shares in coal or nuclear power
5: Far more chance of protests from those who believe conspiracy theories.
6: Lower maintenance needs to other forms of power generation meaning smaller need for trucks / parts / other pollutants.
7: With maintenance will keep generating power for as long as the sun lasts.
8: More likely to generate complaints from those who think they, contrary to all peer review testing, can personally detect radiation / unusual static / goblins in the air.
9: Solar could genuinely power the entire planet without the need for any other power supply. At the moment the issue is not the generation, it is the storage and transport of that power. A large farm in the Sahara could generate enough for the world - if the desert was covered completely in the panels. But at the moment there is no way to efficiently transport that power all across the globe.
10: With luck a brave government not beholden to Power industry campaigning will at some point force all building companies to install panels on the roof of all new build properties, sufficient to power that property completely at the very minimum.
It's not impossible, it's just impossible now.
Mind you, so are drummers.
IIRC it was a reflecter farm with a central collection tower rather than panels. The main issue was that the odd bird that flew near to the collector tower, in the path of the reflected sunlight was getting to about 10,000 degrees in under a second.
I think it was there. Saw the doc at the beginning of the year.
It's only useful to illustrate the relative scale of the area needed - much like saying that you could actually fit the entire human population of the world on the Isle Of Wight if we all stood shoulder to shoulder.
What really frustrates me is this...
https://www.theguardian.com/environment/2019/aug/01/fossil-fuel-subsidy-cash-pay-green-energy-transition
You don't need to put 'Planet Before Profit' - you can have both, there are vast profits to be made by investing in clean energy, and it's incredibly short-sighted and perverse that governments and the large oil corporations aren't doing so now that renewables are reaching the tipping point where they're actually cheaper than fossil fuels.
