We're in the process of doing away with our backline and just putting everything through the PA and I understand the need to cut down on long unbalanced leads etc. If I look at, say, Gear4Music, DI boxes vary with passive units, battery powered units and others working off phantom power and prices anywhere between about 15 quid and a grand! I'll be playing guitar through a Tonelab SE. The other guitarist will alternate between using a Pod and going direct whilst our bassist will also be direct.
I'm assuming - tell me if I'm wrong - that the active DI boxes can cope with longer cable runs. We only play pub type gigs so the longest cable would probably be around 8m.
So: Should we go active? If we use battery powered (the cheaper option) am I going to be replacing them every time we play? Help, experience and recommendations please. Realistically a budget of £30-£40 per unit is probably enough to stop some of the others having a heart attack.
http://orchid-electronics.co.uk/
I use Radial units. I use Pro D2 (passive), J48 (active) DIs, SB-4 for piezo instruments, and IC-1 isolators.
R.
Eqd Speaker Cranker clone
https://twitter.com/spark240
Reddit r/newmusicreview
Eek!
