emg 81/85 pickups - noise problems!?!
MLten80MLten80 Frets: 162
edited August 2019 in Making & Modding
morning gents
i'm having problems with my guitar..
 its got the emg 81/85 set with the 24v mod
its frequently making whoosy/windy noises & crackling etc..
 (ill try & capture a vid later to demonstrate)
i've briefly tried to work out if its a pot/input issue by rolling down each pot & flicking the switch trough the 3 positions..
 later i'll be trying a 9v battery, swapping some pots etc
i've tried 3 amps, & the other 2 guitars with emgs in & they are fine...
but has anyone else experienced problems with this set?
 bit vague like, but i'll try & get audio/vid later
 it doesnt sound like the battery dying (that usually goes all quiet & lpf sounding in my experience)
any suggestions/advise appreiciated (except binning them obviously )
  • I’d suggest emailing EMG as they’ve been helpful for me in the past. http://www.emgpickups.com/contacts
    My guess is is you’ve got a bad connection or wire, but the only way you’ll find that is changing things on at a time.
  • MLten80MLten80 Frets: 162
    edited August 2019
    Cheers fishman
    I'm going to whip it apart later & have a tweak
     I'm going to have to RIP the other apart too to test if one of the pickups has gone
     Failing that I might go up town & get a new wiring kit
  • FunkfingersFunkfingers Frets: 14412
    Mine too.
    Is this system Quick Connect, old-fashioned hard-wired or a mixture of both?
    It would also help to know what selector switch and control pots you are using.
    Mines all solder less except for an oak 3 way switch
    Hmm... home shortly, time to deconstruct  :)
    Do you have an EMG157c Buss board in the circuit?
    Yes indeed, I have a spare so might try that first
    So, yeah
    After some messing about..
     It turned out to be the 2x a23 batteries doing a massive flap
     Either dying or suddenly not liking it (after some months of being completed)
    Luckily I worked it out after checking some wire & bypassing all the pots
     (I was about to leech the bus & output from another strat that would have been more things to put back together lol )
    I've taken the 24v loom out & put a new 9v in
    Weird, I only play an hour or so here n there during the week & few lots of 2-3hrs practice over the weekend.... a 9v usually lasts me 7 or 8 months
     My gfs guitar with the 24v mod has lasted longer.
    I'm going to stick to the 9v again. 24v is cool but the heavier sound it makes is a little love it or hate it.
    Anyway
    /waffle :)
    Cheers for the input lads
    I suspect that your problem may not have been the +24v power supply mod so much as the current capacity of the A23s compared to PP3s.
