Telecaster without serial number
smooresmoore Frets: 30
Morning all
Without a serial number on the rear of the head stock, is there any way to identify a Telecaster?
I have zero reason to believe that it isn't genuine, the shop that sold it to me is very well respected and I've been using them for many years - but I need a serial number for insurance purposes.
Would the number be anywhere else on the guitar?
It's a 1952 hotrod reissue if that makes any difference?
Many thanks,
Simon
  • tone1tone1 Frets: 5173
    edited August 2019
    Yes, I had a 52 Hotrod Tele with no serial number which was correct when I researched it. I seem to remember it was on the bridge plate..
  • smooresmoore Frets: 30
    Thanks for the quick reply - any idea why there was no serial number?
    I think that’s how they used to do it originally in the 50’s
  • KittyfriskKittyfrisk Frets: 18847
    It will possibly be on the neck heel where it is bolted to the body or the neck pocket.
    The re-issues were said to have the the serial number stamped on the bridge plate too, but I can't verify that as sadly I don't own one  ;)
  • TeleMasterTeleMaster Frets: 10256
    Check the bridge plate.
  • TINMAN82TINMAN82 Frets: 1846
    No serial anywhere on my AV52 tele
  • ICBMICBM Frets: 72471
    If it's a '52 reissue the serial number is stamped onto the bridge, and if the bridge has been changed - for example for the Fender 6-saddle one - then there will be no serial number on the guitar any more.
    There may be a sticker with it inside one of the body cavities.
    You’re right, I thought it was a patent no. for some reason.
    Thanks all
    There is a five digit number underneath the "pat pend" no the bridge - so this is the serial number??
    I'd also assumed it was a patent number!
  • FunkfingersFunkfingers Frets: 14491
    The pre-2013 AVRI '52 Telecaster outfit included a six saddle replacement stamped steel bridge. The only legend stamped into this alternative bridge is the word FENDER, perpendicular to the line of the strings, à la CBS era.
  • robgilmorobgilmo Frets: 3503
    smoore said:
    Thanks all
    Put into Fenders serial check and find out.
  • uncledickuncledick Frets: 406
    robgilmo said:
    smoore said:
    Thanks all
    Doesn't work with the AV52s.  Totally random numbering.
    Guitar dater?
    Tried Guitar dater and got this which can't be correct (unfortunately):
    Your guitar was made at the
    Fullerton Plant (Fender - Pre CBS Era), USA
    in 1960 - 1961
    Production Number: 63929
  • MattFGBIMattFGBI Frets: 1602
    Message me the serial and I’ll have a look tomorrow.
    This is not an official response.
    contactemea@fender.com
    Thanks Matt - I've sent you a message
