I'm busy trying to fit a Gotoh Ti-TC1S 3-Saddle bridge to my Telecaster Thinline 69. Got it all on, but when I tighten up the four mounting screws, the front end of the plate lifts up slightly so that it isn't properly flush against the body. I've tried the screws from the original bridge, and the new screws that came with the Gotoh, but it doesn't make a difference.
I decided to try and make a narrow shim out of a thin strip of business card, and I've slid that in between the four mounting screws and the string holes. This does seem to have helped, but obviously the back end is now ever so slightly raised.
I'm guessing the original screw holes must be positioned slightly differently to the Gotoh bridge plate.
Does the shim seem like a good idea or is there a better way of fixing this?
There is no need for a wire trapped under the bridge itself.
Sometimes it can make them too microphonic - some people put a little silicone sealant or similar under the front of it to damp out the vibration.
