I like the caveat 'UP to 40 MB/s'.
Just got some Sandisk 32GB cards rated at 80MB/s read and write, and I get about 41MB/s in both directions.
I need an SD card for my cameras, I have a choice, Ultra or Ultra plus, can you tell me the difference please, the specs on your site seem contradictory.
Noah G.: Just a minute please
Noah G.: The main difference between the two models is the Warranty
Noah G.: The Ultra SD card has 10 years while the Ultra Plus has lifetime warranty
Noah G.: The speeds are the same and the two cards may have minor differences in the technology
Noah G.: What is the model of your camera?
Robert Gilmore: Can you confirm the read and write speeds on both?
Robert Gilmore: I have a video camera , Canon, not sure of model , and a Canonb 800d DSLR.
Noah G.: The read speeds of all products are published on our website. Kindly note that for write speeds, when it comes to the Ultra line they are not published
Noah G.: If we are talking about the C10 80mbs Ultra SD card, it has a read speed of up to 80mbs, same as the Ultra Plus 80mbs
Robert Gilmore: So both ultra and ultra plus C10 will have the same 80mbs write speed?
Noah G.: If you go to the specifications of the cards you can see the read speeds are the same: https://www.sandisk.com/home/memory-cards/sd-cards/ultra-sd
Noah G.: https://www.sandisk.com/home/memory-cards/sd-cards/ultra-plus-sd
Noah G.: The only exception is the 8GB card that is slower
Robert Gilmore: Perfect, and this will be enough for HD video and DSLR shooting RAW?
Noah G.: Just a minute while I check the host device
Robert Gilmore: Thankyou.
Noah G.: The cards should work fine however do keep in mind that for HD video we recommend V30 cards which are faster.
Noah G.: V30 cards are from the Extreme lines and are more expensive.
Robert Gilmore: Thank you, you have been most helpful, I will look for a v30 card for the video camera.
Noah G.: Is there anything else I can help with?
Robert Gilmore: No, you have been most helpful, thank you.
Noah G.: Thank you for contacting SanDisk Customer Care. Keep in mind you might receive a one question survey for our support. We would appreciate if you filled it in!
Noah G.: Have a good afternoon!
Robert Gilmore: You too. Bye.
On their site it says read speeds of,
Ultra Read Speed: up to 40 MB/s
Ultra plus Read Speed: up to 48 MB/s6
So I am still none the wiser.
Given the variables that the manufacturers cannot influence or foresee, such as computer age, bus speeds, interface etc. you'll never get them to give an exact statement of speed. Same applies to broadband, mobile cover, 3/4/5G speeds.
Annoying, but not entirely unreasonable.
Try photography sites for real world experiences.
Hope you feel better soon
Read speeds only matter if you are connecting via a USB 3.x interface, anything USB2 will run at USB2 speeds
You could have ordered six off Ebay, and when they arrived they were just bits of plastic with metallic paint on the contacts, there were no circuits inside at all!
Flippin chancers!
I have cards that says 45mb/s on them and at the time they were the fastest that i have, now they are the slowest. All the cards I buy now is 170mb/s, but then that is the read speed.
They are all V30 Class 10 cards, UHS-I. I do have some UHS-II cards but only 1 pair and I can't take full advantage of it as my camera only have 1 UHS-II slot, the other is UHS-I. You will always be bottleneck by the slowest.
https://www.7dayshop.com/
