SOLD. Blues Jnr IV
BintyTwanger77BintyTwanger77 Frets: 2208
edited September 2019 in Amps £
The MkIV is definitely an improvement on previous models, no more ice-picky highs and the new reverb sounds so much better.
This one has recently been fully serviced, checked over (including valves, one replaced), and converted to 240V by the tech at JPF Amplification on Denmark Street (London). The amp is in superb condition, with dust cover and footswitch for the "Fat" boost. Full specs here:
  • Series: Hot Rod
  • Amplifier Type: Tube
  • Height: 16” (40.6 cm)
  • Width: 18” (45.72 cm)
  • Depth: 9.18” (23.31 cm)
  • Weight: 31.5 lbs (14.3 kg)
  • Speaker: One - 12” Celestion® A-Type
  • Inputs: One - 1/4”
  • Channels: One
  • Controls: Reverb, Master, Middle, Bass, Treble, “Fat” Switch, Volume
  • Effects: Reverb
  • Wattage: 15 Watts
  • Preamp Tubes: 3 x 12AX7
  • Power Tubes: 2 x EL84
  • Cabinet Material: 3/4” Particle Board
  • Amplifier Covering: Black Textured Vinyl
  • Grille Cloth: Lightly-Aged Silver
  • Handle: Molded Plastic Strap with Nickel-Plated Caps
  • Knobs: Chicken-Head Style Pointer - Ivory
  • Control Panel: Black
  • Pilot Light Jewel: Red Jewel
This is for collection only, based in SE London but can travel a reasonable distance for pick-up. Looking for £350 PPG.
PM me if you’re interested. Cheers.
