i know he uses Mesa amps now, pretty sure t was Fender then though. A black Les Paul, cry baby, probably some sort of rack delay. I reckon I hear a phase 90 too but tough to tell!
Nick’s a really nice fella, happy to talk gear all day if you can get in touch with him on Facebook or Twitter.
https://www.google.co.uk/amp/s/www.guitarplayer.com/.amp/miscellaneous/the-verveand39s-nick-mccabe
Spot on, thank you.
Can be tricky for records; even if a player was famous for playing a specific guitar or amp at that time, it's so often the case that in the studio they might have used one of the engineer's guitars on one song, for example, or an amp that happened to be in that studio rather than the one they usually use themselves.
There's also the case that it might have been double tracked and different guitars used for each layer.
Then there's the processing that goes on during the mix so frequencies are cut/boosted, compression is applied etc.
A lot of the time, of course, you are able to find out the exact gear used but just sharing what I've found in general in case the answers you find don't seem to match up to the sound you heard.
Just realised that’s his gear from A Storm In Heaven. I like that album better anyway. The only thing that really changed I think was that he started using Les Pauls.
Such a great musician.
Too bad Ashcroft believed his own hype post UH, and pursued releasing scores of excruciating middle of the road ballads.
Sorry if this is straying too much from the topic but any other suggestions from the Brit Pop era for good albums that also have good guitar playing or tone?
Graham Coxon from Blur
Dominic Chad from Mansun
Bernard Butler from Suede
Gaz Coombes from Supergrass
In fact, I even did a post on here about it.
5 years ago......
https://www.thefretboard.co.uk/discussion/21065/cab-idol
I know where the famous Strat is hiding as well - just shows it doesn't always have to be '59 this, Brazilian rosewood that for era defining tone.
Fag end of Britpop and largely ignored or ridiculed but for sheer guitar tone, the Seahorses - Do It Yourself has to be worth a listen. By no means perfect but a great guitar album, sounds magnificent as well probably due to a certain Mr Visconti on the controls too. Yeah, it's not 'the Roses" but worth a look if you can get by the dodgy lyrics and the lack of Ian Brown on it.
Cheers
Hugh
www.proudhoney.com
Suede - Suede/Dog Man Star
If anybody is curious what direction the Verve were heading in post UH had they stayed together, some demos were leaked a while ago. The band wanted them on the UH anniversary edition release but Ashcroft blocked them:
Sweet and Sour is a great example of what McCabe can do to elevate a tune.
