If they have standard wire terminals then any normal speaker cable will do.
Basically looking for complete cables, although I guess I could also assemble them if needed. They're for a friend of mine who found some old speakers.
https://www.leadsdirect.co.uk/shop/hi-fi-2-pin-din-speaker-lead-2-5m/
Although probably better to make them yourself.
electrosmart Pack of 2-2 Pin Din Male Hi Fi Speaker/Loudspeaker Cable Plugs with Screw Connections https://www.amazon.co.uk/dp/B00512QE4I/ref=cm_sw_r_cp_tai_jNHyDb5C5PK50
That way way you can use slightly better cable than the bell wire that’s usually attached to stuff like this.
I’d probably go for something a little more heavy duty.... there’s a 2x1mm which would do the trick...
electrosmart 25m Red/Black 2x 1mm 2x 89 Strand Speaker Cable Wire for Home HiFi/Car Audio etc https://www.amazon.co.uk/dp/B071CDM5ZG/ref=cm_sw_r_cp_tai_vS3yDbP1642EV
