I then polish with high grade sandpaper and then micro mesh.
Until it wears out (ie after my lifetime) I’m using a fine toothed metal file blade. Not a cheap B&Q file, but a proper engineers metalworking file.
http://www.thefretboard.co.uk/discussion/61134/sarge/p1
This should give a bit more room for error ( ie non flatness / straightness of the neck ) when levelling and shouldn’t really matter for playability since the neck is never completely straight when under tension.
Discuss ?
I use a rectangular piece of 8mm glass (bevelled edges from glass merchants) that I spray glue wet-n-dry to. Cant remember which grit, but you can change as you like. The glass was cheap, it can be any length you want (mines about 7-8"x3"), and you can use any abrasive paper you have access to. It is also perfectly flat (at least as far as frets go. This is the way I was shown at Bailey guitars.
Adam
Often simple ideas are good ones, and efforts to over-engineer/complicate things dont do the job any better, just more expensively
Adam
https://www.chrisalsopguitar.co.uk/shop/guitar-tools/fret-levelling/Diamond-Fret-Leveller-File-TF020
StewMac beam for me with strips of abrasive attached using double sided tape.
