I keep changing my mind about this. So why am I getting rid of it then? Well, I've tried to convince myself I love it but in truth have never really bonded with it. I bought it when the AC30 that I've owned for my entire adult life was temporarily out of action. But then I found someone local to sort the Vox out and, well, that was it for the Torres. I've been meaning to shift it for ages now but just when I'm about to list it, I try it out again, just to make sure everything's still working, and change my mind because it sounds so good. However, it's simply not getting used and I've got my eye on something else…
10" Jensen C10Q speaker, 1 x GZ34 rectifier, 2 x 12AX7 preamps, 1 x 6L6EH output
Line output with volume control (no reverb)
Never gigged and in damn near as new condition, although there is a little scuff on the cab (visible in the pic but close-ups available on request); AIUI, by the time you've totted up the extras it was specced with, these retail at a bit over a grand made up or £600 or thereabouts in kit form.
The guy I bought it from didn’t include the original sales receipt so I've no way of knowing whether this was a kit amp pre-assembled by Barry Vyse, or sold as a kit and constructed by someone else, either at home or under supervision on one of the Vyse ampmaking courses. On balance, I think it was a kit amp but at this point, it's hard to say. Either way, it was all hand-wired and a pretty tidy job too.
£450 £400 £350 £300Base theme by DesignModo & ported to Powered by Vanilla by Chris Ireland, modified by the "theFB" team.
From http://vyseamps.com/single-ended-class-a-designs.html
Boxer Plus
Development of the Boxer incorporating additioanl features. There are models KT12 and KT66, named as a tribute to the classic 'Rolls-Royce' of audio valves, the M-OV KT Series around which the Super Boxer range of amps was designed.
Both amplifiers are\ single channel amps with valve rectifier, high and low gain front end inputs, a full set of tone controls and master volume control. Reverb can be fitted to models as an option.
All have the cleanliness, warmth and superb harmonic distortion of the legendary Class 'A' circuitry coupled with the modern power, full gain, volume and tone flexibility.
With this form of construction, the amp retains its true pre-amp characteristics, including its controlled over-driven tones, over a wide range of output volumes making these amps the most flexible in application, giving warmth and sweet clean tones at lower volumes, with the classic Class 'A' overdrive when cranked.
Boxer Plus has:
• Two pre-amp valves (12AX7) • Single power valve (6L6/6550/KT66)* for pure single-ended class A operation • Valve recifier (GZ34) adding vintage dynamics • Normal and high gain inputs • Gain control, volume, bass, mid, treble and master volume controls
Model KT12: uses a 6V6 output valve producing 6 watts. Would normally be supplied in small cabinet with 10 or 12 inch speaker. Reverb is optional.
Model KT66: uses 6L6 output valve with original KT66 as optional extra and producing 15 watts. Would normally be supplied in small cabinet with 10 or 12 inch speaker. Reverb is optional.
*all can be supplied with vintage KT66 Series Marconi-Osram valves if specified
