My Jackson has a VLX53 5 way selector. I've wondered if it's all wired up and working correctly as the neck pickup (Duncan JB Jr) doesn't seem to be able to match the bridge humbucker in terms of output.
I've tried a few different pickups in the neck and they've all sounded under powered.
https://m.imgur.com/gallery/8L5C2i6http://img.photobucket.com/albums/v28/maliciousteve/IMG_20190915_084451_zpsuzaslinv.jpgAs you can just make out I've got the black wired to the selector, red and white taped off and the green and bare wired to the ground (the copper tape where all the ground wires and wired).
Is that correct? Could it be a faulty switch?
The VLX53 is a cheap piece of crap. It usually fails through heavy handed use. The PCB prises away from the white half, weakening the internal contacts.
Finally, the JB Jnr N pickup is not as ferocious as its full sized bridge position namesake. (None of the neck position Duncan Li’l ‘buckers is especially “hot”.)
It could well be the selector may be on its way out then. I took it out this morning and it does look a bit knackered.
If you do want to parallel the switch, connect terminals 4 and 5 (wire to the volume pot), and terminals 1 and 6, 2 and 7, and 3 and 8.
Connecting the grounds to the copper tape is OK, but I would want to solder a wire between the pot ground terminal and the tape as well, not rely on the physical contact between the two.
