Good afternoon. I've reached breaking point with trying to record with this thing and am in desperate need of help. I've had the ui24r for a few months, and have gigged with it plenty of times. I love it, it's brilliant. But now I want to use it to record (with Reaper) and it's being very confusing (almost certainly my fault - I hate this tech stuff).
Anyway, I can get input channels working fine, and can record. The problem is, I can't listen to any of it! There's no audio coming from Reaper back to the ui24r. I managed to get my old Tascam thing to work, and a little Focusrite thing. But not this bugger. All hell gratefully received.
If direct monitoring is off, and your DAW has input monitoring turned off, then your DAW will show that it is receiving signal and you will be able to hear playback after recording, but you won't hear any audio while recording.
Band Stuff: https://navigationofficial.bandcamp.com/album/silhouette-ep
I was trying to monitor from the Soundcraft, so: mic > Soundcraft > DAW (new and existing tracks) > Soundcraft > headphones. It must be a settings thing, but I can't work it out.
I've turned direct monitoring on for every track, but I'm unclear on what I need to do with the Reaper audio device settings. At present I've routed output to channels 1-32 of the Soundcraft. The ASIO drop-down isn't offering me any alternative. I think I need to do something with the Soundcraft monitoring settings, but I'm struggling to work out where the hell I go.
Correct me if I still have this wrong. The issue you're facing is that after you've recorded something through the soundcraft, you can't play it back through the soundcraft. Presumably, your speakers are hooked up to the soundcraft.
If my above understanding is (finally) correct, can you monitor your guitar through the soundcraft? i.e. hear the guitar as you play through the soundcraft.
If it is playback that you're having trouble with, it may be a routing issue..
The solutions @Stuckfast outlines are a bit much for my brain to handle -- sorry! So, I wonder if there is a DAW with which Soundcraft works more intuitively? My loyalty to Reaper has suffered a pretty substantial hit in the last few days.
Again, thank you for your help everyone. It is much appreciated.
I have no idea why this would be a design decision on the part of Soundcraft/Reaper/both.
Anyway, I'm now attempting to set up a stereo out from Reaper back to the Soundcraft for monitoring, as per @Stuckfast's second solution above. Will let you know how it goes...
I can't work out how to assign the outputs from Reaper to go back to the Soundcraft and actually work. None of the terminology makes any sense. Now I want to go and live in a monastery somewhere and never have to think about computers again.
Annoying. But...I will be victorious.
So, starting over, I understand the input routing (1 goes to 11, 2 to 12, etc) and have got that working, but I'm now trying to patch to USB-DAW and am only getting sound from channel 8. Channel 7 shows activity in the soundbar thing, but it makes no difference where I route it to: sound only comes from channel 8.
I have absolutely no idea what any of this is or does (there are loads of patching options and I'm just staring at it with no clue), so I'm going to have to start from scratch I think, and actually learn what it all means. The important thing is that I can scrape through the recordings next week, so thank you for your help @Stuckfast and @Branshen . You probably saved some hardware from meeting a violent end.
https://youtu.be/IvF4H-aAsGg
