Wanted it to look more like furniture than gig gear so there we go
Speaker is a Jensen C12q, good thing it’s light because the cabinet is heavy as f***
I copied the dimensions of the H&K 112 cab since I will be using it with my Black spirit 200.
It’s a bit too late to try it now but will try and give it a blast in the next couple of days.
Have you got any more details on the build? It's something I'd like to try at some point too.
There are also plywood bits all around to screw into, I could have used pine there to save weight but it was easier to order it precut to right dimensions, I did have to recut a bit here and there though when the fit was too tight.
I cut the hole for the speaker with a jigsaw and got the hardware ( feet, handle, jack socket ) from hot rox uk, speaker from Thomann.
The front panel is screwed from the inside using a long handle screwdriver.
The sides and front are 12mm ply, which makes it heavy but also more surface to glue.
Back is 9mm ply wood I think.
Edit: I should mention that I ordered most of the plywood from “cut my plastic”, and while it wasn’t cheap, it was very high quality plywood and accurately cut.
Hopefully will put it through its paces tomorrow.
Will update with more when I’ve tested it proper loud.
certainly looks very classy
Bandcamp
I can compensate with the amp since it has a post preamp bass control so it’s not a problem.
