I am certainly old enough to recall the product being reviewed in a British music magazine. (Best guess, International Musician & Recording World.) Forum hoarders might possibly have a copy of the actual edition.
Last year, I worked on a modified Gordon-Smith guitar that had an odd-looking, epoxy-sealed, box of passive electronic trickery. (Probably, involving an inductive coil.) It is possible that the eVe13 does something similar to passively filter the pickup signals.
I think the Gordon Smith device (I discussed it with John years ago) was akin to the Villex "passive boost" http://www.villex.com/boosters.html
Unless you really like out of phase sounds - NB, the standard Strat 2 and 4 positions are *not* out of phase despite often being called that - then it’s really not very useful... fiddly to use and giving a lot of duplicated sounds.
I suspect that’s what this is since that switching - although there are 27 possible switch positions - gives only 13 different sounds:
Any individual pickup (3)
Any two pickups in phase (3)
Any two pickups out of phase (3)
All three pickups in phase (1)
All three pickups with any one out of phase (3)
There are no others because reversing the phase of all selected pickups doesn’t change the sound.
What would make it more interesting is if the pickups are wired in series not parallel - still only 13 sounds, but the differences both in tone and output are more dramatic. That’s how Brian May’s guitar is wired. Unfortunately you then lose the two classic Strat parallel-in-phase sounds.
Edit - ah, I couldn't see the chart earlier! It is basically as I expected, and sounds like the pickups are in parallel.
The difference is that the original BMRS circuit has the pickups interconnected in series. Parallel is not an option without one of two modifications.
The eVe13 blurb indicates that its first seven permutations are the same as a Stratocaster with a five-way lever plus a Gilmour-style seven sounds mod.
The “up” sounds involve “filtering of the waveform”. That suggests either simple notch filtering by phase reversal or the introduction of a Villex type black box to the circuit.
I've got one of those switches if you want it, donate £10 to the tFB, send me your address and you can have it.
Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
Thanks
