You might find the right connector here
You need a mono, switched, solder loop one. They're available on Amazon and Ebay if you can't find one locally.
https://www.amazon.co.uk/CL1160A-Socket-female-switch-angled/dp/B013RJ875K/ref=sr_1_5?keywords=cliff+jack+socket&qid=1569485179&s=gateway&sr=8-5
https://www.ebay.co.uk/itm/6-35mm-1-4-Panel-Mount-Mono-Jack-Socket-CLIFF-ELECTRONIC-COMPONENTS/133168331841?epid=20007738958&hash=item1f01737c41:g:BdEAAOSwZuxdeTIs
Make sure you check the impedance of the amp's internal speaker and the cab first - if the cab impedance is lower than the amp's speaker, you could damage the amp.
I am looking at getting the 6 pin so i can use 2 spaeakers. I love the fact that the speaker will disengage when changing from combo to a 4 x 4 cab as explained in the mod.
Feedback
Bass 12 sounds a rather good through a 4x12 :-)
Thanks for the headsup
does this jack disengage the 4 x 4 and engage the speaker on the combo when unplugged?
amp wiring to internal speaker acts as normal until you insert plug into the switched jack socket - then combo speaker is disengaged and output goes to your speaker cab of choice .. Remove the inserted external jack lead and output goes back to internal speaker.
- as a word of caution - ensure amp is switched off when performing the swap from internal to external speakers and vice versa to avoid any issues.
