Ebay mark7777_1
The Facebook group has a lot helpful members and advice but there are also quite a few users on here so if you have specific questions just ask away.
John P.Yes I believe it was accessible through the Tribe forum,but the "Forum" accessible from there now is nothing like the original,which I believe started life as an XR32 Forum & Wiki,but the original format seems to have disappeared,but i'll keep at it.
Are you an XR18 user ?.
Cheers,Graham.
In the meantime con anyone help me with a question about the effects section on the XR18?
When i'm on the "Main Section" I see a different reading of the Fader levels on the 4 FX returns,compared to if I view the return faders by clicking on the 4 FX buttons on the right of the mixing section,i hope i'm making this clear,it's harder to explain than I thought it would be.
Thanks.
https://imgur.com/dzxUk2g.
https://imgur.com/ehz2Ssb
1. -4.8 on channel 14 is the signal being sent to FX3 (compression).
2. -5.8 is the level which the FX sends back to the mix.
So, if you want to change the amount of compression on George’s vocals then you move the slider on channel 14. If you want to change the overall amount of compression in the mix then you move the level on the extreme right. This is a bit easier to understand with Reverb rather than Compression.
In Image 1 when the "Main" button is selected the "FX" Faders are showing as Unity.
In Image 2 when the "FX3" Button is selected the "FX" Faders are showing as Zero.
In other words the Fader values are not tracking between the "Main" & "FX" Buttons,so I don't know whether to set the "Return" values from the FX button page or the Main button page.
I'm really doing my best to make this clear,but even as i'm typing i'm confused reading it back
On the fx page use the channel faders to decide how much effect you want each channel to send to the effect.
On the main LR output mix screen (and monitor busses) turn up the four fx faders to choose how much effect you want to hear overall in that mix.
Ebay mark7777_1
Many thanks to you both,i should have realised I was looking at different functions for the FX Faders on each tab,old age is not what it's cracked up to be sometimes .
Just out of curiosity,why would you want to do that ? & of course that would explain the mad oscillation I've heard from time to time,from the Returns,i presume.
Thanks,Graham.
Ebay mark7777_1
How do you control the levels/ouput for 17/18 Line,can't find the fader location & as far as I can tell no Manual info ?
help please
