My next experiment, soon, will be to lower the whole nut by filing or sanding the flat bottom of the nut, at least to get closer to a good setting.
All my previous attempts have led to pinging and buzzing on the 3 unwound strings, because no cheap file will get down to a 10.
I know for me personally that it's not worth me buying the files but for you it sounds like it will be.
The links below show you some of the best tools for cut nuts slots, the whole lot is a silly amount of money but if you want to do the job properly it's the stuff to get. Their are video links on each page well worth watching, if you don't buy their gear it will give you some idea how to do nut slots.
https://www.stewmac.com/Luthier_Tools/Tools_by_Job/Tools_for_Nuts_and_Saddles/StewMac_Safe_Slot_Nut_Guard.html
https://www.stewmac.com/Luthier_Tools/Tools_by_Job/Tools_for_Nuts_and_Saddles/Double-edge_Nut_Files.html
https://www.stewmac.com/Luthier_Tools/Tools_by_Job/Tools_for_Nuts_and_Saddles/Nut_and_Saddle_Vise.html
Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
Yes, they are expensive but when eventually they wear out completely I would not hesitate to buy the same again. In a heartbeat.
