AX8 users - can you help?
BeexterBeexter Frets: 599
edited October 2019 in Amps
I'm trying to work out how I can run a cab sim on the left channel main out (Output 1) and no cab sim on the right channel main output.
I know you can do it using the FX loop block (using output 2) but that's not an option as i have pedals in the AX8 effects loop.
It must be possible as i believe you can run a different cab ir on the left and right channels, i just can't work it out.
I have posed a similar question on the Fractal forum but wondered if anyone here has a solution. Any ideas/ suggestions?
  • RolandRoland Frets: 8712
    Does the AX8 have mixer blocks? If so then put them in parallel. You can use one to pan hard Left, and route that to Output1. The other is panned hard Right and goes to the CAB block and then Output2.
