Mosky Dual Switch users....
BeexterBeexter Frets: 599
edited October 2019 in FX
......are the switches soft touch or hard click?
May be a replacement for an FS-7 on a cramped board......
  • I replaced Boss FS6 x 2 with these - soft touch - work splendidly
  • BeexterBeexter Frets: 599
    Schweet....may well give one a go in that case.
    What pedal you going to use this with ?
    I had an ambition is to use the Mosky with a boss RC 30 - failed
    Fractal AX8 - I'll double check but i think it can work with both NO and NC momentary switches but thanks for the heads up
  • Using mine with a Boss MS-3 if that helps
  • TheMarlinTheMarlin Frets: 7879
    Soft touch.
  • Using 2 of them with a Kemper rack for some poorman's FX on/off profile & up/down action.
    Cheap and very good.
    Thanks all. I bought one over the weekend and it seems to be just the ticket. Small footprint , low cost and soft touch switches- result.
