You can check for a faulty preamp valve simply by substituting each one in turn for a known good replacement.
I'll try replacing the pre-amps one at a time to see if that has any effect.
Haven't had time to swap the valves in the cub yet though, so I'll start there. If not a dodgy valve I'll need to find a local tech to check it out. Used to have a great guy in Edmonton but I think he may be retired now.
