It's finished, but.......
I have finally completed my Princeton kit build, bar from a couple of valves I need to buy.
However, I'm too damn scared to try turning the thing on!
I like being not dead, mostly.
Maybe I'll just use it as the "sure, you can jam with my band" reserve amp :D
Turns out there is an H in Haych! ~ Sporky
Bit of trading feedback here.
  • lysanderlysander Frets: 574
    edited October 2019
    Put some electrician gloves and goggles on, Stick a multimeter at the end of the jack and check that 1) nothing is smoking and 2) you don’t have 1kVolts waiting to get on your guitar  ?
  • KeefyKeefy Frets: 2286
    If you can get it to Swindon once you have your valves, I can have a look over the wiring and then bring it up to power slowly on my Variac whilst monitoring the current draw.
  • HaychHaych Frets: 5628
    I might take you up on that if you don't mind bud?  Swindon isn't very far away, probably about 45 minutes.  This kinda thing definately calls for a 'thanks' fret.
    No probs, just PM me when you're ready.
  • hywelghywelg Frets: 4303
    edited October 2019
    Just make yourself a light bulb limiter. Power it up with no valves to start with, if the bulb glows then goes dim you're OK.  if it continues to glow brightly you have a short somewhere. Then add pre amp valves and check again. Then add output valves and check voltages on all anodes are within spec.
     Make sure you have a load connected.
    If all is OK plug in and play. If you get terrible feedback reverse the connections on the OT primary. (is the Princeton push-pull with negative feedback, not sure?)
    This kinda thing, maybe an in-line switch between the supply and bulb?
    https://images.app.goo.gl/d7vYCiUofCubkLkZ7
    That's one. Not hard to make, the hardest thing now is finding a suitably powerful (100W or more) incandescent light bulb - i.e. not halogen or LED!
