One thing I've always struggled with; picking stuff off a record and learning it. I'm better than I used to be but not as good as I want to be.
I'm currently trying to learn a solo, which isn't complicated, and I know I have the ability to play, but I just can't figure it out. It's not helped by the fact that it's written in a harmonic minor key (I think), which is a bit alien to me. It's not fast but it's taken me an hour to get the first bar. So damn frustrating.
If I slow the track down it still isn't slow enough to pick out the individual notes and then you just get the sample rate confusing things too.
There must be an easier way of doing this, surely. Or is it just a case of our old friend Percy Veerance?
Turns out there is an H in Haych! ~ Sporky
Bit of trading feedback here.
I don't slow things down when learning- I use Transcribe! to play the maximum number of notes I can recognise at once, finding them on the neck.
If that is one note at a time then so be it.
I did a video about how to transcribe music for the forum a while back, I will see if I can find it.
Yes it is perseverance.
I can't sing for toffee either. I break things down into phrases also and then imagine/hear the phrase in my head.
As has been said earlier, it's perseverance. Then you get to recognise certain phrases or combinations, and permutations of those phrases. However, I can only do that quickly with my largely blues/rock vocabulary. If it's some jazzy phrase I'm completely unfamiliar with, it's sometimes down to working it out very slowly.
Its great software - works with videos as well - I often download a youtube tutorial and loop the phrase Im learning - slow it a bit to get the phrasing correct (and check how its being played in the video), then speed it up.
Ebay mark7777_1
I find the looping feature really helpful for nailing phrasing.
It looks like a great tool, I did download it and started using it and comparing it against Transcribe! The interface is very friendly but after about a minute of using it Capo deliberately overlaid irritating white noise over the track I was using and flagged that it was because I was using the trial version.
How on earth you're meant to be able to trial a piece of software that is deliberately functionally impaired is beyond me. The only way to evaluate it properly without white noise is to buy a subscription.
So, no, sorry, does look good but I won't be subscribing. At least Transcribe! allows me a full 30 days to decide if I want to buy a license.
Import song, right click and "Item processing" then "explode multi channel audio to new one channel items" ... then click the phase button on one of the new tracks. This will cancel out most of the vocal and bass and kick so you can hear guitars better.
Highlight a section your learning and then hit the toggle repeat button so it loops the bit your interested in constantly
To slow a track down without changing the pitch hold down Alt and drag the right hand end of the track to the right
To change pitch on old recordings where tape transfers changed the pitch slightly use the Playback Rate slider at the bottom of the edit window .... hold down Ctrl while moving the slider for more precise movements in pitch
Insert the EQ plugin on a track and high pass it around 400Hz and lo pass it around 4K to hear the guitars better
There's probably more but I use the above all the time
Play solo at gig. Spend the extra time you would have wasted on working it out on talking to the chicks who are mightily impressed with your solo.
This works for me, except the last sentence, which was from my imagination.
