Well ive just finished tonight fitting a new switch, CTS push pull volume control, neck and bridge pickup and a complete re-wire, now previously, the shop I gave my guitar to wired it up very strangely and the volume pot acted more like a tone pot, its now working properly now ive re-wired it.
However, this got me thinking, there is plenty of room to add a tone pot in there, any thoughts on this ? is it worth it, its a fairly easy wiring job.
The 2 pickups I went for was a DiMarzio Air Norton in the neck, I used to have one of these years ago, and kind of missed it so thought id grab one and stick it in the neck, and a Seymour Duncan dimebucker in the bridge, lovely sounding pickup.
Part of the Nuno sound is the absence of the loading effects of a tone control pot. If you are not fussed about that aspect, a CTS (or better) audio taper 500k pot would do the job. If you require the with/without option, the simplest option is the Fender No-Load™ tone control kit in 500k guise.
One final thought. Are you left-handed? I'm not sure that the Fender No-Load is available with a reverse resistance taper and detent. (ICBM can probably enlighten us!)
The bill Lawrence that was in there was starting to get a bit old and tatty looking, the guitar has got to be coming on for 10 years old now, so I thought I'd grab the dimebucker and pop that in instead, it came with the Washburn 621 or 623 in the neck, whatever it was, it was a junk pickup, so I changed that for the air Norton.
I was looking at the 500k Seymour Duncan tone pot with an orange .022um cap ?
There's actually very little difference between a normal 500K tone pot up full and a no-load - it is audible, but it's not huge. .022uF is the usual tone cap value for a humbucker guitar. Cap type/brand is irrelevant to tone, but Orange Drops are nice as they have good thick leads which make them easy to fit.
https://sixstringsupplies.co.uk/
Our YouTube Channel for handy "How-To" Wiring Tutorials
If Nuno’s tone is entirely in his fingers, you have to wonder why his Washburn Princess signature model needed more than one control pot.
https://www.facebook.com/benswanwickguitar
https://imgur.com/bLyk3iz
https://imgur.com/86RBKV0
https://imgur.com/ya40Frg
For several reasons, I would have installed the Duncan reduced friction pot as volume and the CTS push-pull as tone.
Because there could be a complete strip down coming soon as personally I think the guitar is too yellow looking, I prefer the look of the N4 vintage look, so a major sanding could be on the way which would give me the opportunity to rewire it all up, however, again im not too sure on this as the guitar body is basswood, im still trying to make my mind up.
Although the strip down would only really require me disconnecting the pickups, switch and output jack, the rest could come out as a whole.
Until recently, the majority of push-pull pots found in electric guitars have been of the smaller "dime" diameter. The dimensions of the inner working parts place these smaller pots at a disadvantage from day one. They do not work as well. They wear out sooner. The push-pull mechanisms are prone to failure.
It makes better sense to deploy such vulnerable parts where they will receive less use. i.e. As tone controls. A knackered tone control may reduce functionality whereas a knackered volume control might silence a guitar completely.
