I bout a used MIM strat from ebay and I love it. but one thing is really bugging me.
the saddles don't seem to fit. to me the seem too wide. it is not really affecting anything but (does not show up well in the photo) the outer saddles are being pushed outwards so don't line up straight.
the outer 4 strings don't sit in the middle of the saddles so I am not sure measuring the string spacing is a good reference
Apart from that it looks fine to me, but they probably need adjusting for height and definitely for intonation.
The saddles should each be set flat, parallel to the baseplate, not following the string radius.
I have not even tried the roland pick up as I don't have a syth to plug it into. I got the guitar at a good price as the roland was untested
https://www.thefretboard.co.uk/discussion/165035/is-this-a-good-buy-and-is-it-genuine#latest
there is a gap at the top but they are touching at the base and that is what made me think they could be the wrong size. I did try squeezing them in together.
everything looks original on the guitar and I cant think of a reason why you would change the saddles unless you changed the style of saddle. I may be just looking for fault where there is none
Start with them set like this, it won’t be too far out -
The US version had die-cast saddles and a two-point bridge. This is the Mexican version, so those are the original saddles.
I did buy a GR20. Lots of fun but I need to learn to play a bit better first so I'm just consentrating on playing through the normal pickups for now
